questions about python
Go to solution Solved by dany_boy,
Eliminate this:
while True:
    GPIO.output(22,False)
    GPIO.output(27,False)
    GPIO.output(17,False)
    while GPIO.input(24) == False: #rood
        print("rood aan")
        GPIO.output(17,True)
    while GPIO.input(23) == False: #groen
        print("groen aan")
        GPIO.output(27,True)
    while GPIO.input(18) == False: #blauw
        print("blauw aan")
        GPIO.output(22,True)
use if statements instead:
while true:
	if GPIO.input(24) == False:
		print("rood aan")
	else:
repeat for each channel
Hi there,
I recently wrote this tiny program just to control a LEDstrip from a raspberry pi with buttons for each color. So far all it can do is light 1 color at the time, when either one of the buttons is pressed. How could I make it so that I can have multiple buttons pressed at the same time?
Another question: How can I make it so that I can use all those different colours? Right now I only know how to have either blue, red, green or all those at the same time.
My current code is:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(17,GPIO.OUT) #port voor rood
GPIO.setup(27,GPIO.OUT) #port voor groen
GPIO.setup(22,GPIO.OUT) #port voor blauw
GPIO.setup(24,GPIO.IN,pull_up_down=GPIO.PUD_UP) #knop voor rood
GPIO.setup(18,GPIO.IN,pull_up_down=GPIO.PUD_UP) #knop voor blauw
GPIO.setup(23,GPIO.IN,pull_up_down=GPIO.PUD_UP) #knop voor groen
while True:
        print("rood aan")
        print("groen aan")
        print("blauw aan")
https://linustechtips.com/topic/762820-questions-about-python/
Eliminate this:
while True:
        print("rood aan")
        print("groen aan")
        print("blauw aan")
while true:
		print("rood aan")
	else:
Quote or tag if you want me to answer! PM me if you are in a real hurry!
Why do Java developers wear glasses? Because they can't C#!
My Machines:
The Gaming Rig:
-Processor: i5 6600k @4.6GHz
-Graphics: GTX1060 6GB G1 Gaming
-RAM: 2x8GB HyperX DDR4 2133MHz
-Motherboard: Asus Z170-A
-Cooler: Corsair H100i
-PSU: EVGA 650W 80+bronze
-AOC 1080p ultrawide
My good old laptop:
Lenovo T430
-Processor: i7 3520M
-4GB DDR3 1600MHz
-Graphics: intel iGPU :(
-Not even 1080p
https://linustechtips.com/topic/762820-questions-about-python/#findComment-9639233
55 minutes ago, Cyborgium said:
Hi there,
Sample each of the buttons in your execution loop and set the LED state based on the state of the button. Assuming sampling the input spits out a 0 or 1 and the output can use a 0 or 1, then I would do the following:
while True:
    red_btn = GPIO.input(24)
    green_btn = GPIO.input(23)
    blue_btn = GPIO.input(18)
    GPIO.output(22, red_btn)
    GPIO.output(27, green_btn)
    GPIO.output(17, blue_btn)
And in fact, you could replace the variable names (red_btn, green_btn, blue_btn) when calling GPIO.output with the sampling function. But Python philosophy discourages that.
However, if they strictly take a True/False, then:
while True:
    red_btn = GPIO.input(24) == True
    green_btn = GPIO.input(23) == True
    blue_btn = GPIO.input(18) == True
EDIT: Thanks to Python's loose typing, True = 1 and False = 0, but nothing else. So 0 or 1 should work with those functions.
https://linustechtips.com/topic/762820-questions-about-python/#findComment-9639509
1 hour ago, dany_boy said:
Eliminate this:
while True:
        print("rood aan")
        print("groen aan")
        print("blauw aan")
while true:
		print("rood aan")
	else:
I tried the if statements instead and it worked, thanks!
https://linustechtips.com/topic/762820-questions-about-python/#findComment-9639758
