Help with FreeNAS sharing
Go to solution Solved by Eniqmatic,
Just now, peej said:
well it doesn't even show up in windows at all
Go to start, run, then type "\\192.168.3.22" and hit enter (no quotes) and what do you get?
You will need to provide a little more information than that, what have you done so far, what does your config look like, what errors/troubles are you running into?
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
so im running FreeNAS corral, i have a RAID 1 array im trying to set up CIFS sharing however i cant find it anywhere what else do you wanna know?
I lurk a lot
It's called SMB in 9.10/10/Corral. So you need to create a dataset, then go to Storage > Shares and create a new share from there. I'm doing it from memory as don't have it in front of me just now but I think that's what the menus are.
Please mark as answered if it helped :)
The reason you are probably not seeing it picked up automatically, is that you haven't joined the machine to the same workgroup/domain as your other machines.
oh okay cheers
I lurk a lot
