higher quality surge protector/uninterruptible
Hi,
Any good high quality surge protector/uninterruptible power supply for the wall?.
Right now I'm using this one:
https://www.amazon.com/APC-6-Outlet-Protector-SurgeArrest-P6B/dp/B0002RSPE4/ref=sr_1_17?ie=UTF8&qid=1491420452&sr=8-17&keywords=apc+surge+protector
but, it's causing electrical issues with my GPU.
That's only an 840 joule Surge Protector.  If using a surge protector with a full computer setup, I'd be running 1600-2000, or higher, joule rating.  If you're going with a UPS, for small systems I'd recommend 1200-1500VA rating.  However, my regular desktop, with a 1000W PSU, has a higher end video card and 4x 24" monitors connected.  I run a 2800VA UPS on that system alone since it also has speakers and other devices connected in the surge suppression only section of the UPS.  Treat Joules very closely to wattage, and give yourself 20% overage in rating for peak draw.  You need to identify wattage of ALL equipment plugged into the Surge Protector/UPS and provide that 20% overage for peak.
I don't have any method to calculate that on my PC. I just need to buy something quickly.
This is my personal formula, and it isn't a widely used standard practice in industry (nor is it using any standard naming convention other than to provide understanding of the equation). However, it fits most any home situation, and should keep you out of trouble.
PSU wattage [PSUW] + total Wattage of additional connected devices [CDn+nW] = Attached Device Total Wattage [DTW]
DTW x .25 = Peak Overage compensation [POW]
DTW + POW = minimum wattage/joule rating
IE:
850W PSU
100W LCD
45W lamp
80W speakers
850 + 100 + 45 + 80 = 1075W
1075 x .25 = 269W (rounded up)
1075 + 269W = 1344W
1344 is the minimum wattage or joule rating you'd want for the listed setup.  My 2800VA UPS is rated at 1400W and would be a fit for this scenario.
On 4/5/2017 at 3:37 PM, RodoGodo19 said:
Hi,
As said they are two different things, if you want a UPS what are your system spec we can determine what your requirements will be. For a surge protector as said that is a pretty basic unit my go to recommendation is this one:
https://www.amazon.com/APC-Protection-SurgeArrest-Performance-P11VT3/dp/B0012YLTR6/ref=pd_sim_23_3?_encoding=UTF8&pd_rd_i=B0012YLTR6&pd_rd_r=WC40T11SPT71A67EGEFG&pd_rd_w=lOSr7&pd_rd_wg=MrvA7&psc=1&refRID=WC40T11SPT71A67EGEFG
IE:
850W PSU
100W LCD
45W lamp
80W speakers
1075 + 269W = 1344W
I need help to buy something better.
My pc is:
i7-7700 non-k
16gb
2x hdd 3.5"
1x m2 drive 960 evo
evga 850 g3
gtx1080ti
dell monitor 24" 1080p
so, which one do you recommend me?, future proof too, I don't know if I will add more stuff to my pc later
5 minutes ago, RodoGodo19 said:
-SNIP-
Your system won't draw more than 550W at full load so having a UPS right around the 700W range would be more than adequate with enough overhead for your periperhals and networking equipment.
Something like theses would be a good option for your needs, with some extra for more hardware:
https://www.cyberpowersystems.com/product/ups/cp1350pfclcd/
http://www.apc.com/shop/us/en/products/APC-Back-UPS-Pro-BX1350M-Compact-Tower-1350VA-AVR-LCD-120V/P-BX1350M
