Microphone recording low voice?
4klips
My computer mic is recording very low voice. But, actually I am speaking loud and clear.
So, how can I fix this by tweaking any settings or anything else? Please help.
be happy? people will respect you because of how deep your voice is.
A8-7600 {} Gigabyte FM2+ Board {} CX430 {} Corsair Vengeance LP 8gb {} MSI GTX 760 2GB {}
Console.WriteLine("C# is aids");
it's a serious problem. Please help me.
The recorded audio is very frail and low even I turned the volume up to maximum. How can I fix this.
your mic may not be connected properly, plug in into the rear or front panels.
Actually i have already done this. Nothing changed.
What applications is it low in?  Have you checked windows settings and what microphone
What are you recording with? What mic?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
I am using this mic
http://www.amazon.in/iball-Rocky-Headset-Over-Ear-Headphone/dp/B006526G50/ref=sr_1_1?ie=UTF8&qid=1491395801&sr=8-1&keywords=iball+Rocky+Headset+Over-Ear+Headphone+with+Mic
And I am trying to record it with Camtasia, OBS, etc all are same low voice recorded.
The problem is solved.
I changed the format from 44100 Hz to 48000 Hz and increased microphone boost from 0dB to 10dB.
Now its loud enough to be heard clearly.??
It's likely that boost is going to cause white noise, so if it is - you can look into two alternatives.
First, Equalizer APO (and the graphical front end named Peace) may allow you to get a better fine tuning of the boost you need. The lower the boost that is still clear the better, typically.
Second, a USB dongle like a Sabrent USB stick or Syba USB stick will likely provide more power to the mic, thus decreasing the need for boost. It also helps filter EMI. They'll cost you 6-10 USD.
Of course if you are not hearing white noise don't fix what ain't broke :D
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
