Just now, skuded said:
I was curious if anyone ever modded their peripherals. Im not sure how many parts of your mice, keysboard, and most important, headset, can be disassembled for painting.
Since its possible with a graphicscard, why not try it on a bunch of other stuff. :)
because paint tends to peel off when rubbed, and it adds weight, etc. not worth it imo.
A8-7600 {} Gigabyte FM2+ Board {} CX430 {} Corsair Vengeance LP 8gb {} MSI GTX 760 2GB {}
Console.WriteLine("C# is aids");
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631797
Well, I have modded headphones in the past. I have mainly painted them, but I have also made mods to change the sound of some headphones.
I guess I've modded my keyboard aswell (in the lightest sense of the word).
I have installed custome O-rings to make the travel a bit shallower and I've replaced most of the keycaps with metal keycaps.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631808
i was thinking of getting metal WASD keys, do they wear quicker
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631810
Depends. There are a lot of companies that make metal keycaps and in my experience they vary a lot in quality.
It also depends on the quality of the keycaps you're replacing. Some plastic keycaps wear down faster than others.
The only thing I dislike about metal keycaps is that they're really loud when you bottom them out, which is why I had the O-rings made.
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631820
i use dental bands for braces and i just have 2, it works
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631836
23 minutes ago, skuded said:
I was curious if anyone ever modded their peripherals. Im not sure how many parts of your (mice, keysboard, and most important,) headset, can be disassembled for painting.
Oh yeees. G710+ and G402
https://linustechtips.com/topic/762249-modding-peripherals/#findComment-9631870
