So i just swapped my case out for the anidees crystal AI.  Part of the reason being is that it has a built in fan controller like my old phantom 410 did.
The fan controller is pretty basic.  Gets its power from a molex connector.  Has a 3position switch on top the case Low-Off-High.  all the fans are connected to the factory hub which consist of 5 3pin headers.
Now my problem is if I have the fans on low and put the computer to sleep, upon wake up none of the fans turn back on.  If I flick the switch to off then back to low (or high) the fans will start up.
Leaving it on high is not really a option because it gets LOUD.
Anyone have the case and confirm if theirs does this too?
https://linustechtips.com/topic/761979-anidees-crystal-ai-fan-controller/
