21.5 inch vs 23 inch monitor?
greensauce
What's the best deal between these 21.5 inch and 23 inch LG monitor, if the 21.5 inch is 40 bucks cheaper than the 23 inch?
P.s. this is the first monitor I'm gonna have, maybe adding more in the future
I'm literally using a 21.5" and 23" monitor side by side hahaha. I would go for the 23".
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
all I can say is that you're gonna be staring at it a awful lot, so your eyes will probably thank you for the extra inch and a half in the long run
You should consider that a monitor purchase is usually something you don't do as often as other hardware purchases. I personally have had my 24" 1080p display for at least 6 years and then I bought a new one. So buy something decent now and keep it for a while. After all, no matter how great your pc is, you can only enjoy what your monitor is capable of delivering in terms of experience to you.
Get at least a 23" 1080p and please consider an IPS display.
Another question about your post:
Why do you want to add more monitors? Productivity or gaming?
PC: AMD Ryzen 5 3600 @4.2HGhz 1.25V || Noctua NH-U12S SE2 || 16GB (2×8GB) Aegis 3000Mhz CL16 @3200Mhz ||
|| Sapphire Pulse RX 6700 10G || MSI B450i Gaming PLUS MAX Wifi
  || Kingston NV1 2TB m.2 ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
mainly for productivity and multitasking purposes
