Opinions and Thoughts on First PC Build
Hey guys I'm building my very first gaming PC. This is what I have:
https://pcpartpicker.com/list/Hmt2f8
The purpose of this build is for playing at 1080p, 60fps, ultra-high settings.
I wanna it to last long for around 5 to 6 years, and this also means
that I don't want to upgrade it during that time.
I'm not gonna play demanding games like The Witcher 3 or Crysis 3
I do prefer first first person shooter rather than MMORPG
Some games that I will use it for are: GTA 5, Battlefield 1, Battlefield 4,
COD Black Ops 3, Dark Souls, War Thunder, COD 4 Remastered ...
Please let me know what do you think and what would you change.
It's good nothing to change
what about cpu cooler? I'm not sure if the 7500 comes with a stock one honestly, but if it doesn't the cooler master hyper 212 evo would be more than enough for your purposes (and pretty darn cheap)
All non K intel cpu comes with a stock cooler
Haswell comes with cooler for all of their cpu including K ones
Skylake and Kaby doesn't have a cooler for K cpu anymore
It comes with one, all locked intel CPUs usually come with their own cooler
stock cooler is included with the 7500, and it's good enough. 212 evo isn't a good cooler, cryorig m9i and raijintek aidos are both cheaper, smaller and performs the same.
I didn't say it was good I simply recommended something I was familiar with and knew would meet his needs if by chance it didn't have a stock cooler
thank you all for feeling the need to correct me, very informative all around thanks.
i'd suggest this:
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  ($189.49 @ OutletPC)
Motherboard: ASRock B250M-HDV Micro ATX LGA1151 Motherboard  ($61.98 @ Newegg)
Memory: G.Skill Aegis 16GB (1 x 16GB) DDR4-2133 Memory  ($101.99 @ Newegg)
Storage: ADATA Premier SP550 240GB M.2-2280 Solid State Drive  ($79.99 @ Amazon)
Storage: Western Digital Mainstream 1TB 3.5" 7200RPM Internal Hard Drive  ($47.99 @ Best Buy)
Video Card: Asus Radeon RX 480 8GB ROG STRIX Video Card  ($229.99 @ Newegg) performs the same but much cheaper.
Case: DIYPC DIY-J21-W ATX Mid Tower Case  ($44.97 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($47.89 @ B&H)
Total: $804.29
Generated by PCPartPicker 2017-04-04 00:32 EDT-0400
Consider waiting for RYZEN 5, take a look at this:
Want to custom loop?  Ask me more if you are curious
Plus Ryzen  will only get better with time
Your build looks good, I would suggest you change the 2x4 ram sticks to 1 8gb stick. this will make upgrading easier in the future. Also unless you are aiming for specific Nvidia features, I would recommend RX 480 8gb since you say you want it to last for 5 - 6 years. Nvidia has a history of stopping support when a new line comes out whereas AMD cards tend to be supported for a lot longer. Plus right now the RX480 is pretty much equal in DX11 and performs better in DX12; plus it's cheaper.
Ryzen 5 comes out in a week, I would wait and see if you can hold off for a bit longer. If anything, depending on Ryzen 5 performance, the Intel chips might get a small price cut. A build with Ryzen 5 1600 (6cores/12 threads) that, again depending on performance might be better if your hoping for the system to last a few years.
In PCPartPicker, it's set as Ryzen 7 1700 since there is no 5 yet but I manually edited the price to that of Ryzen 5 1600(launch price might be a bit more). right now the build comes up to about $20 more than yours. Leaked benchmarks of the i5 7500 vs Ryzen 5 1400 shows it to performance about the same or better when overclocked. And when games are better optimized for the Ryzen chip, we can probably expect better performance.
But again the last two paragraphs will depend on reviews in a week and how game developers optimize. I would say wait and see.
https://pcpartpicker.com/list/sJcXpb
Is there any Mobo like the one that I put
But just a AMD edition
this build uses honestly identical parts but with ryzen, rx480 and a single 8gb stick instead of 2x4
