38 minutes ago, Farken_OJ said:
Hey there,
Just wondering what people think on if the case that I chose goes with my current build?
Build
All things not listed as purchased are part of the upgrade
I'm assuming the weird things with the ram, SSDs, monitors, etc. is cus you haven't quite made up your mind...
but that's a good case to my knowledge, almost got myself once upon a time
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625082
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625087
I was upgrading my ram for the 8GB and put the corsair in with the chance that it wouldn't work and it did which im happy about. Also the SSD's are all in my current computer the 500 HDD and SSD where my original things then I found the other two things.
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625092
smart choices, that clears it up nicely.
thanks for humoring my curiousity.
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625123
1 hour ago, Farken_OJ said:
Hey there,
Build
Here's my 2 p400 builds for reference. And I do love this case.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625389
2 hours ago, Farken_OJ said:
Looks great, what sort of PSU do you have? a modular one? just wondering for cable management purposes
My setup (the one with the shot glasses) has a full modular psu and my wife's has a non modular psu. There is a lot of places to hide wires in this case.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/761708-right-case-for-build/#findComment-9625737
