Just now, skkler said:
So i was planning on building a computer case but im nto exactly sure wat i would need part wise. (standoffs, brakets, plates,m sutff like that) would anyone happen to be able to help me out with a list?
You will need a rear IO plate ideally as it would be much easier than to fabricate something from scratch. Places such as mountain mods sell parts, another option would be to cannibalize an old PC case.
http://www.mountainmods.com/mountain-mods-modular-io-panel-p-486.html?osCsid=ll375taiq954r7vj41h63ffpn7
https://linustechtips.com/topic/761597-custom-case/#findComment-9623553
i found alot but i couldnt find anything for inserts for motherboard standoffs
https://linustechtips.com/topic/761597-custom-case/#findComment-9623968
If your installing into wood you can directly thread into it but if you want an insert something like this would be good:
https://www.fastenal.com/products/details/11100216
https://linustechtips.com/topic/761597-custom-case/#findComment-9624092
