Just now, IAR117 said:
Lel, I know, but my mobo has CPU fan 1, 2 Nd cha fan 2. Would it go in cha fan 2 or CPU fan 1?
Cha fan = chassiss fan. As you are talking about a CPU fan, plug it into CPU fan1.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
1 minute ago, IAR117 said:
Got it thanks. New question, how do i place my mobo into my P400s? I know, sorry, I'm a newbie.
Just place it, it may require you sliding it to get the io lined up on the shield, but it it will lines eighth up with the the standoffs.
Actually scrap that. Where do i get the screws for doing that
Ussually the case, read the manual.
There will be standoffs on the largest empty panel for your motherboard to sit on depending on its form factor (i.e. ATX, mATX or mini ITX)
EDIT: screws in case packaging and don't forget the IO shield 1st. I suggest watching a basic build video. Process is generally the same due to standards.
There's only one way to place mobo. If you need to ask question like that, I highly recommend reading manuals for your components. Maybe watching build guide or two.
Case has package with all screws you'll need. Refer my point above.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
20 minutes ago, IAR117 said:
I did it some time ago guys. Sorry just me having a brain fart.
Here's a good video to follow along if you're still having trouble:
