Using Link Aggregation with WD MyColud PR4100
Solved by Gaub,
You won't see any advantages from your laptop but link aggregation would allow you to saturate gigabit connections to two clients at the same time. Even if a client had two gigabit adapters, you would only see gigabit throughput from the NAS to a client. If you do want to do it you would need a managed (smart) switch that supports link aggregation. Netgear makes them.
Agall ·
Posted in Mobile Gaming1 -
2
3
DudeSquad11 ·
Posted in Audio1 -
Mando772004 ·
Posted in Troubleshooting2 -
1
rohleder00 ·
Posted in CPUs, Motherboards, and Memory11 -
Old_Liver ·
Posted in Laptops and Pre-Built Systems0
