You mean RAID? I think windows had something built in that allowed for something like this... though I didn't try it, so I wouldn't know :P
CPU: Intel Core i5 2450M @ 2.5Ghz RAM: 8GB GPU: HD Radeon 7470M (Potato) Mobo: No idea, probably a pumpkin.
My computer is a laptop.
BF3 on minimum settings = 25fps @ 720p
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042695
Yes you can put it in RAID 0 to make it a 4 TB drive. Or you clean it up. :b
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042700
It can be done a couple of different ways in Windows. The simplest and most robust would be to add folders on the new hard disk to your libraries. In addition to simplicity, this approach has the advantage that loosing one disk will not result in the loss of data on the other.
An alternative would be to create a spanned volume. The problem with this, as with RAID 0 and JBOD is that they are not fault tolerant and loosing one drive means the total loss of data on all drives in the volume.
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042726
you might be able to partition the 2tb one into 2 1tb then use raid 10? needs a minimum of 3 drives so i dont know if this would work :/
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042747
Does using RAID 0 increase the fault chance or is it the same chance as any drive failing?
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042756
Why would you want them to act as one? Have 2 separate drives and use that to organise your files. Sounds like you've got a lot of mess if you've filled up a 2tb drive. ;)
Because its all pretty much games and using 2 drives could be annoying for Uplay Origin and steam
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042761
It does not increase the fault chance. BUT if one of the two drives fail, you will lose all data, since the information is spread across both HDD's when in RAID 0.
Main Rig
Phone
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042765
The chance of a fault is increased because a fault on either drive means the loss of data on both. In other words, the chance of each drive in the array failing does not change, but the chance of the array failing increases.
In RAID 0 parts of a file may actually be written on each drive. In fact that is likely for files of any size.
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042767
pretty sure raid 0 will half the total storage?
raid 0 with (2)128gb ssds means you only have 128gb of ssd storage? it just gives you increased performance.
i dont think theres a point to doing anything to the guys hdd's he should leave them be
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042802
RAID 0 splits writes across the drives. RAID 1 writes the same data to both drives.
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042815
No. That is incorrect. Watch Linus' TechQuickie about RAID.
Main Rig
Phone
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042823
Raid 0 doubles theoretical speed and size from 1-2 drives, raid 1 has roughly the same speed, the same size but with increased fault tolerance.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042825
didnt say anything about RAID 1
okay well your statement was still wrong then with you saying you can get 4tb..
EDIT - sorry my bad, i didnt realise he already had a 2tb hdd, i thought he originally had a single 1 tb hdd
with RAID 0 you get twice the read and write performance and you keep the physical capacity, but each drive you add makes the failure chance increase..
2 drives = 50% more of a chance of failing
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042840
That is correct, but your original statement was wrong.
Main Rig
Phone
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042851
yeah i admit it was wrong.. probably would have been a good idea to read op properly too :S
https://linustechtips.com/topic/76053-hard-drive-question/#findComment-1042878
