Hello is there any programs to monitor temperature on an AMD A8-7410 i have found one only and it said the processor was not supported im curios what temperature the system is running at as the fan is ALWAYS full speed as soon as it starts up its been about 4 months since I got the system as well
https://linustechtips.com/topic/760434-help-required/
I suggest you to use AIDA64. It shows all the temperatures, voltages, even the cooler's RPM and many other things.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/760434-help-required/#findComment-9611061
MSI afterburner, NZXT CAM, or just check the BIOS.
you might want to adjust the fan curve if the fanm automatically jumps to 100% on boot though
https://linustechtips.com/topic/760434-help-required/#findComment-9611068
