Overclocking issues.
Solved by Imakuni,
Just now, Mikius10001 said:@Glennieboyyy007 @Imakuni Thanks, I'll see what I can find when I get home. If anyone knows a reliable channel or tutorial (not just the first one that pops up) it would not go unappreciated. Side note, what are people opinions on where I should aim for with a 212 EVO? is 4.0 -4.2 a reasonable goal? Or are my eyes bigger than my stomach?
Expect 4.2~4.3 out of a 212 EVO.
On 12/03/2017 at 3:36 PM, Imakuni said:Quick guide:
- Put voltage on manual, I suggest 1.2v as a starting point. Leave the frequency at stock.
- Stress test with Prime95 Small FFT for about 5min.
- If max temp is:
- Below 81C, increase voltage a notch and repeat step 2
- Between 81~83, move on.
- Above 83, reduce voltage a notch and repeat setp 2.
- Once you've found your max voltage, start increasing core frequency. Stress for about 1h, until you've found instability; at that point, back off to the previous value.
- Once you've got that, go for a lengthier 8~24h test. If stable, congrats, you've got your OC. Otherwise, knock the multiplier down a little.
