Hi...please tell me good case under (60$ to 85$)
Right now i hv cooler master n300
System info:-
Cpu:-i7 6700
Cooler:-deepcool maelstrom 120t liquid cooling
Mobo:-gigabyte h110m-s2 ddr4
Memory:-kingston16gb
Hdd:-wd blue 1tb
Gpu:-msi gtx 1080 reference card
Psu:-seasonic s12ii 520w
Ups:-intex 1000va gama
Case:-cooler master N300
https://linustechtips.com/topic/759081-new-case-help/
System info:-
Cpu:-i7 6700
Hdd:-wd blue 1tb
I can vouch for the Phanteks P400 series.  I have both the P400S with acrylic window and the P400 Tempered glass version.  Both are easy to build in with lots of space inside.  Good build quality with good customer service.  And the other case I would recommend would be the NZXT S340.  You can't go wrong with that one either.
Here are pics of mine and my wifes P400 cases.  I am running the XFX RX 480 RS and she is running the MSI RX 480 Reference version.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/759081-new-case-help/#findComment-9594400
Nice build....nzxt looks solid but elite version not this s340 and does hv lot of space..big problem is with my liquid cooling because pipes r short i dont know i thnk the radiator cannot reach on the front
https://linustechtips.com/topic/759081-new-case-help/#findComment-9594490
If your going to use the same aio in your pic you can mount it up top. The p400 Has front and top fan support. And with the smaller aio you should have no issues mounting it identically like yours already.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/759081-new-case-help/#findComment-9594540
