Stock fans
36 minutes ago, Julius159 said:I have 4670k 4.4GHZ temps are 68C, lowering fan speed does not help they are loud even at idle.
fan spins about 1180rpm when playing games
expect high rpm and noise while playing games, its noise or high temps.
water cooling benefits those really high end CPUs and cards that need heat transferred to ali fins with higher surface area than what air cooling provides, and you still need those annoying fans + a pump.
If you look at Jayz2cents builds; his are really expensive but he has quite a good setup where he has very large radiators and lots of fans at low rpm; VERY expensive to do.
I dont think you need that extra complexity to get silence, because i have silence with an AMD-FX which is the butt of CPU heater jokes. I have 4X 140mm PWM noctua fans as intake and I have 1X120mm PWM noctua fan as exhaust. I have no fan on my CPU, because I can line up my exhaust fan with my CPU cooler, it makes the CPU fan pointless. Its summer right now and I previously only had two intake fans and they would ramp up on and off, by adding two more intake it keeps the temps below the 55C i set for min temp. It will still ramp up playing games nothing can really stop that.
I hope this helps in what ever you end up doing
