Hello,
So I'm using MSI Afterburner for CPU + GPU temps in my tray. CPU temp is not showing average temps between all cores, but rather the highest core in Celcius. I want it to show average temps of all cores instead of highest core. Are there any software out there that monitors average CPU temps between all cores? I tried Speccy, but system tray icon does not update on boot, need to exit & reopen everytime. Thanks in advance.
On the pic below, you can see the yellow number is the highest core in Celsius from AfterBurner, where I want average temps instead.
Main:  1650 v2   @ 4,6GHz   -   X79 Deluxe                -   GTX 1080 @ 2000MHz   -   24GB DDR3 @ 2400MHz / CL10
Side:   i7-4790K @ 4,5GHz   -   Maximus 7 Hero        -   GTX 1070 @ 2114MHz    -  16GB DDR3 @ 2666MHz / CL12
HWBOT
https://linustechtips.com/topic/758297-software-for-average-cpu-temps-in-tray/
I don't know what programme can give you an average, but I know when I look at temps I look for the highest core temp, as even if it's at lets say 87C for a brief second, I still know that I have insufficient cooling because it got so high, to answer your question, I don't know, because normally you are just interested in the highest temp, cause if one temp gets too hot, all the cores can get too hot, and that is not a good thing to have.
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
21 minutes ago, deXxterlab97 said:
Coretemp can do that iirc
Resulted in same as MSI Afterburner, just highest core, or highest CPU if multi-CPU setup :(
HWBOT
35 minutes ago, LoGiCalDrm said:
You could check if HWmonitor, OpenHardwareMonitor or HWiNFO fits your needs.
Didn't find anything, thanks though.
HWBOT
yh core temp, you can put average core temps in the tray. like i've done here on my desktop
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
So you want CPU package average? Or all cores individually and average?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Those are temperatures of each core. That's not what I'm looking for.
I want a software that that has the possibility to show in tray the average temp of all my cores, like Speccy. Take this picture as an example: 55c+57c+56c+55c+57c+58c = 338c / Divided by 6 (amount of cores) = Average of 56c, as showed in picture below.
HWBOT
yeah obviously i customized it, you can choose to just have a single number for average across all cores.
Home PC:
Work PC:
I tried the option you are speaking of, and that is exactly the same as package temps from HWmonitor. Speccy's average temps are like 5c below package temps on any software, and I would like a software that calculates avg temps in this same formula as Speccy, and NOT any package avgs.
HWBOT
I checked all software I got installed and can't find any that would give that kind of option. You might need to create script for some software to do that, or find someone to do it for you.
yeah if you are being this specific and picky, it's time to write a VB program to do this for you.
Home PC:
Work PC:
