I don't know if this is suppose to be in this section, if it's wrong sorry.
So I need a build (pref 120Mhz monitor and will run bf4 at 120 FPS) I got $4,000 to spend on this rig but it have to inculde the monitor too, could someone please make a good build for me? Thanks!
Emmh... Maybe consider killing yourself before you talk to me?
Pople on this forum though some of them had a brain, turns out, no.
https://linustechtips.com/topic/75816-help-me-with-a-build/
Do you want a costume loop?
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039327
I don't know what that is, and just got a new payment, if there's needed for it could cost $5,500.
EDIT: This will be for gaming.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039338
Do you want to watercool? (AIO or a full loop) and i can work with 5500$.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039341
Yes, I'd prefer watercooling I've though about overclocking if you Think that's an idea
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039353
Do you want me to max out the 5500$?
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039358
Sure, do that it can be little over so you don't have to downgrade something.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039362
Are you wanting to water cool your rig or anything? You could build a BF4 pc on ultra to run it at 1080p 60fps for around $2,000.
$4,000 would just be a waste in less you plan on water cooling the pc.
Edit : Sorry didn't see some of the other posts. Water cooling alone would cost anywhere from $500 - $1000.
So the total rig might cost about $3,000 (Again, $4000 would just be a waste in less you also plan on using it for gaming/photo editing and video editing at super high speeds)
こんにちは, まだ学習漢字 ;)
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039374
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($279.99 @ Microcenter)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($129.99 @ Newegg)
Motherboard:  Asus MAXIMUS VI GENE Micro ATX LGA1150 Motherboard  ($192.99 @ NCIX US)
Memory:  A-Data XPG V2 16GB (2 x 8GB) DDR3-1600 Memory  ($159.46 @ Amazon)
Storage:  Samsung 840 EVO 500GB 2.5" Solid State Disk  ($338.00 @ Mac Mall)
Video Card:  Asus GeForce GTX 780 3GB Video Card (2-Way SLI)  ($516.98 @ SuperBiiz)
Case:  Corsair 350D Window MicroATX Mid Tower Case  ($79.99 @ Microcenter)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($95.99 @ Adorama)
Monitor:  Asus PB278Q 27.0" Monitor  ($549.00 @ Amazon)
Keyboard:  Corsair Vengeance K70 Wired Gaming Keyboard  ($129.99 @ Newegg)
Mouse:  Razer DeathAdder 2013 Wired Optical Mouse  ($52.99 @ Amazon)
Speakers:  Creative Labs GigaWorks T3 80W 2.1ch Speakers  ($249.99 @ Microcenter)
Headphones:  Corsair Vengeance 2000 7.1 Channel Headset  ($159.99 @ Mwave)
Total: $3698.50
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-11-13 15:06 EST-0500)
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039383
Total: $3698.50
I Think I could get better parts, I don't need any mouse/headphone/keyboard only monitor as I'm running a 75Hz at the moment.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039389
Then remove the parts you don't need and you got yourself a beast pc :)
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039398
You do not need 120/144hz. It's not worth it for the price (Not talking $ but color and res)
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039409
120Hz increases the response time in BF4 belive me, if you've tested it one time you wouldn't want to play on your rig.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039430
If you look at my PB278Q you will never ever want to go back to a 120/144 Hz. TN Panels are bullshit and 1080p is meh.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039442
I guess you're not a BF gamer...
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039467
I hope that's what you think of GSync.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039476
GSync seems to be awesome but if it's a TN only then no.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039481
Hint: Its not TN only :)
Really? I thougth it was?
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039516
This is what I got
CPU:  Intel Core i7-4930K 3.4GHz 6-Core Processor  ($576.98 @ SuperBiiz)
Motherboard:  Asus P9X79 WS SSI CEB LGA2011 Motherboard  ($359.99 @ SuperBiiz)
Memory:  Mushkin Essentials 32GB (4 x 8GB) DDR3-1333 Memory  ($269.99 @ Newegg)
Storage:  A-Data Premier Pro SP900 256GB 2.5" Solid State Disk  ($199.99 @ Amazon)
Video Card:  Asus Radeon R9 280X 3GB Video Card (2-Way CrossFire)  ($315.98 @ SuperBiiz)
Sound Card:  Asus Xonar Phoebus 24-bit 96 KHz Sound Card  ($175.98 @ SuperBiiz)
Case:  Corsair 900D ATX Full Tower Case  ($269.99 @ Newegg)
Power Supply:  Zalman 1000W 80+ Silver Certified Fully-Modular ATX Power Supply  ($261.49 @ TigerDirect)
Operating System:  Microsoft Windows 8.1 - OEM (64-bit)  ($98.98 @ OutletPC)
Monitor:  Asus VG248QE 144Hz 24.0" Monitor  ($266.99 @ B&H)
Other: 360mm rad from EKWB ($87.48)
Other: EK-Multioption RES X2 - 250 Basic ($49.18)
Other: EK-D5 Vario (12V DC Pump) ($107.58)
Other: TUBE PrimoChill PrimoFlex™  ($27.29)
Other: TUBE PrimoChill PrimoFlex ($27.29)
Other: EK-CSQ Fitting 10/13mm G1/4 - Black ($6.14)
Total: $3975.57
(Generated by PCPartPicker 2013-11-13 15:43 EST-0500)
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039542
If you don't know what a custom loop is I don't think you should be building a custom watercooling loop yet, especially for a first build. Stick with an AIO like a H330, H220, H100i, or Kraken X60.
Can't buy the H330, or H220 in the US... only thing you can get close to the the H220 is the one cooler master just came out with.
https://linustechtips.com/topic/75816-help-me-with-a-build/#findComment-1039559
