Define R4 Door Replacement
By
TheRoss0411
in Power Supplies
in Power Supplies
Solved by paulstung,
If you mean the front door, there are 3 hinges on the left hand side with 2 screws on each, just undo the screws and the hole door comes off. If it's just the front panel, open the door and you will see 6 ( I think ) rubber door stops, pop them out and underneath there will be a screw undo those, and the front panel pops off.
Kyle89 ·
Posted in Troubleshooting1 -
1
4
ken43 ·
Posted in Troubleshooting5 -
5
thedood2k ·
Posted in Power Supplies3 -
1
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
