Well sometimes when I load a page the page loads fine but most of the time when I load a page nother is displayed at all other then the background colour. The links on the page still work I presume as the mouse cursor changes icon to the link icon. However when I open a new tab or go to another tab and then go back again the page displays fine. I have tried deleting all my browser history, cookies and everything else but nothing has changed it. I have also disabled all my extensions but there is still no change can anyone help me out. Chrome version is 32.0.1700.6 beta-m Aura.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/75764-chrome-beta-problem-help-needed/
I use it because I like how everything runs. The browser is far more usefull like this then it was before. Bookmarks are far better and browsing speeds are much faster. Plus the entire browser runs at 60 fps.
 (\__/)
If you are using the Canary release, there is never any guarantee that the browser will even work.  Even the other beta versions have only received minor testing before release.  I would just recommend using the stable release for any critical operations.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
