  1. 1 x 24-pin ATX main power connector
  2. 1 x 8-pin ATX 12V power connector
  3. 1 x U.2 connector
  4. 1 x M.2 Socket 3 connector
  5. 2 x SATA Express connectors
  6. 6 x SATA 6Gb/s connectors
  7. 1 x CPU fan header
  8. 1 x water cooling CPU fan header
  9. 2 x system fan headers
  10. 1 x system fan/water cooling pump header
  11. 1 x front panel header
  12. 1 x front panel audio header
  13. 2 x USB 3.1 Gen 1 headers
  14. 2 x USB 2.0/1.1 headers
  15. 1 x RGB (RGBW) LED strip extension cable header
  16. 1 x S/PDIF Out header
  17. 1 x Trusted Platform Module (TPM) header
  18. 1 x Thunderbolt™add-in card connector
  19. 1 x Clear CMOS jumper
https://linustechtips.com/topic/757471-fan-headers/#findComment-9576090
5 IIRC, you can always set up a fan controller
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/757471-fan-headers/#findComment-9576123
