Water Cooling Cost
Solved by Skiiwee29,
Just now, TroubleMaker023 said:Well somebody one told, I only have to drain the loop once a year if I only use distilled water (which I'm planning to do).
Is that accurate, of course I would use PT Nuke along with it.
if your using just distilled water, then yes you would be fine once a year. Only if you were using an opaque additive such as Mayhem Pastel would you want/need to do it every 6 months.
