Planning on a mini itx build with focus on it being a bit of a workstation. Have limited space on my desk which is why I want such a build.
Parts:
Motherboard:
ASUS ROG Strix Z270I Gaming, Socket-1151
CPU:
i7-7700k
CPUCooler:
noctua nhl9i
GPU:
evga 1060 3gb
RAM:
corsair 32gb
Case:
fractal design node 202
HDD/SSD:
samsung 850 EVO-Series 500GB 2.5" SSD
Tad uncertain about the space left for the PSU, if anyone could suggest one that could fit it would be much appreciated.
Not sure about the thermals from the GPU really worth it with this case or not, maybe go for a bit bigger case?
https://linustechtips.com/topic/756136-will-it-fit/
Everything you have looks good to go fittings wise. As for the PSU, you'll need to get an SFX one. Avoid SFX-L ones because they'll barely fit.
Thermals wise I wouldn't sweat it too much. But if you're really worried about it and don't want to get a much larger ITX case, I suggest Silverstone's RVZ-01 or FTZ-01. They have mounts for thin case fans.
https://linustechtips.com/topic/756136-will-it-fit/#findComment-9560956
No retailer in my country that sells them anymore:(
Myeah, sure wish retailers would categorize PSUs by form factor as well.
Found this though Corsair SF600 600W
https://linustechtips.com/topic/756136-will-it-fit/#findComment-9561225
