I am finally moving from console gaming to PC but the game I mostly play is CS:GO and thats about it since I normally play on a MacBook Air. My budget is low so I found something at Walmart to start out with. https://www.walmart.com/ip/Acer-AXC-704G-UW61-Desktop-PC-with-Intel-Celeron-N3050-Processor-4GB-Memory-500GB-Hard-Drive-and-Windows-10-Monitor-Not-Included/46356507
I was wondering if this tower would be able to run CS:GO smoothly enough for me to play. Thank you for any replies.
https://linustechtips.com/topic/755644-need-help/
Eh that's not really going to be a great experience.
Are you selling the old console?  Remember a desktop will be both an actual computer and a gaming machine, so I'd recommend trying to get closer to 500 dollars.
This page has a good list of builds at different price points: https://www.reddit.com/r/pcmasterrace/wiki/builds
The cheapest build is above your budget but a lot better for CS:GO.
X99 build!  Asus X99-A | i7 5820k @ 4.5GHz | 16GB RAM | Gigbyte G1 980 Ti sli | 250 + 500GB 850 Evo + 1TB MX300| 1TB WD Blue | Corsair 450D
Clevo P650RS i7 6820hk | GTX 1070 | 16GB RAM | 4K PLS Display | 1TB Sandisk Ultra II
Dell Latitude E6430 i7 3720qm | 6GB RAM | Nvidia Quadro NVS 5200m | 128gb ssd + 320GB hdd
Speakers JBL LSR 4328ps
Headphone Set Up Sennheiser HD800 | Sennheiser ie800 | Chord Mojo
https://linustechtips.com/topic/755644-need-help/#findComment-9555398
2 minutes ago, Jerbear said:
@TheGhzGuy My friend said if necessary he would sell me his graphics card so I guess yea I would be comfortable with buying used parts.
Perfect! I'll send a video of a few options for you in a couple of minutes.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/755644-need-help/#findComment-9555438
Something like this
If you want, I can try putting something together for you. If you need some stuff for super cheap, PM @CUDA_Cores
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/755644-need-help/#findComment-9555448
Whatever you buy, it'll be faster than Macbook air, atleast those won't have thermal throttling...
-- BSOD : ( --
https://linustechtips.com/topic/755644-need-help/#findComment-9555495
Nah, not even close. The N3050 isn't even close to the i5s included with the Macbook Air, don't think throttling would ever cause a N3050 to beat something like a i5-5250U.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/755644-need-help/#findComment-9555521
For CS:GO you really need a high-end CPU, my i3-4160 only manages ~150fps on ultra (with a GTX 970) - but the CPU is the bottleneck, and the same can be said for most source engine 2 games, as the engine is relatively reliant on the CPU, so if possible go for the best CPU you can (i3, i5 minimum).
https://linustechtips.com/topic/755644-need-help/#findComment-9555549
