Long story short, my new build has suddenly started to give Electric shock when I touch the metal part of it. It wasn't like that before. How should I check what's wrong with it?
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
https://linustechtips.com/topic/755554-help-with-my-case/
5 minutes ago, RKRiley said:
Are all the standoffs in place for the motherboard? definitely something shorting.
Yeah everything was working fine until a few hours ago. Something went wrong, and I don't know why. I guess i'll take everything apart and assemble again.
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554305
How long was "until a few hours ago". A day? A month?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554327
I think a few hours mean "a few hours" on any part of our planet, unless you're travelling with Matthew McConaughey on the Endurance.
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554362
When did you build it. How long was it fine before it started shocking you. That's why I included the "until" in the quote
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554404
Built it yesterday, maybe 20 or 21 hours ago. And it started giving those shocks from three or four hours ago.
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554428
Then yeah, I would check your stand offs. If you're really unlucky you may have gotten a big piece of fuzz behind the MOBO and that is shorting it also. Would try to do that sooner so you don't break anything with electricity
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554441
So, just take it off and put it back again?
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554448
Your best bet. One of the stand offs might be crooked also. Clean the back of the MOBO make sure there's nothing there then make sure you get all the stand offs good and try again
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9554457
I have removed all the stand offs and connected the MOBO to PSU, and used a tester on the metal part of the Case, it's still giving shocks.So, the only way this is happening would be between MOBO and Case contact. Is there something I can place between MOBO and the Case something like a thin sheet?
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9559496
Before any of that, is this normal?
https://linustechtips.com/topic/755554-help-with-my-case/#findComment-9559523
