audio card, needed?
Do you know if your logitech speakers are 5.1 or 7.1 surround sound?
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/75502-audio-card-needed/#findComment-1034500
well i have an old logitech speakers this one:
and i was wondering should i get a sound card and which one should i get and why? also my mobo its z77-ds3h gigabyte
as always thanks
Spend your money on better speakers - a soundcard wont make them better.
https://linustechtips.com/topic/75502-audio-card-needed/#findComment-1034511
better speakers? so this are not good?
If you already have them, and like them, then enjoy them. Just don't imagine that a soundcard is going to make them better, because it wont.
https://linustechtips.com/topic/75502-audio-card-needed/#findComment-1034780
This. My friend has the same set of speakers and bought a 120£ sound card. What a waste, only listens to music on youtube too (not saying thats bad, but if you're after audio quality..).
Current rig: i5 2500k & Gtx 560ti With Filco MJ1 TKL & Neutron Gtx 120gb SSD
https://linustechtips.com/topic/75502-audio-card-needed/#findComment-1034975
