I think you would need to upgrade the PSU first as the 350 Watt is cutting it close but is possible and the r7 370 needs a 6 pin you would need that.
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/754635-will-graphic-card-work/#findComment-9544051
it should work, though the factory recommended PSU is 450Watts.
that being said, your system should consume less then 300 watts with the R7 370 installed i think.
https://linustechtips.com/topic/754635-will-graphic-card-work/#findComment-9544053
12 minutes ago, FakeHeist said:
I have a prebuild hp i want to get a graphic card from the local shop (i can't buy online)
my spec are
i5 660
6 gb ram
350 watt power supply
prepare for this one
a gt 610 graphic card :(
i want to get a radeon r7 370 4GB (from the local shop)
will it work ?
Should work but instead i would get RX460 or GTX 1050
https://linustechtips.com/topic/754635-will-graphic-card-work/#findComment-9544075
Cpu i5-4590 3.3 ghz
Motherboard asus H97 plus
Psu thermaltake 750w
Gpu that r7 i said earlier
Some ddr3 ram(no money to get ddr4 motherboard)
Ps . I cant get online stuff so i have to go to local shop of gaming stuff if you suggest me to get a better they sell a ichill gtx 980ti with triple fan
Ah also the 980ti costz 680 euro the cist all the build costs :P
https://linustechtips.com/topic/754635-will-graphic-card-work/#findComment-9545464
