Hey everyone,
so before I finally free my 980 from my i3 2100, I would like to clear up a few questions.
1. Will a i7 2600K work with my current motherboard? (It is a OEM motherboard by Acer, the original potato pc was called the Acer Aspire M1930)(And here is what the motherboard looks like: http://www.ebay.com/itm/Acer-Aspire-M1930-Desktop-Motherboard-MB-SGC0P-004-socket-1155-/401034451730)
2. Are there any people here that are still rocking a Sandy Bridge system? Because if so I would like to find a "good enough" motherboard that is LGA 1155. Preferably one that has four ram slots, and maybe two GPU PCI-e 16X slots, but most importantly one that is cheap.
3. I have played around with GPU's for the passed 3 years, buying some, selling some, putting them in, taking them out, fairly easy. Are there any things I will need when upgrading? Maybe very small details that linus may not have mentioned in his build logs?
Thanks everyone, im so excited :>>>>
https://linustechtips.com/topic/754536-cpu-upgrade-questions/
1. Yes, that is the correct socket size, LGA 1155 for Sandy Bridge.
2. Some people are still rocking it. There is no leap and bound upgrade from a 2600k to 7700k, maybe 15-20% at most. And this is through the 4 generations previous. You likely will need to find a different Board though to overclock on. I use to have an MSI P67A-GD65 (b3) when I had my i5 2500k and loved the board. You likely will be able to find them on craigslist or applicable type site to your country or ebay. Generally speaking though, people do price gouge a bit for these boards.
3. Your 980 will be just fine. It has performance very similar to a GTX 1070, only missing a few of the features found in Pascal such as Ansel, SMP, etc... You should be just fine continuing with the 980 for gaming performance.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543137
Oops, I sorta messed up number 3. I corrected an typo and then forgot where I was in the question missing out a big chunk of info. What I meant to say is I have experience with GPU's but none with CPU's (Well I have taken plenty of them out of sockets, but never actually installed one XD). Are there any things I will need when upgrading my cpu? Is there like a general guide on how to replace a cpu on a working pc?
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543150
As long as you line the guides on the Chip up with the socket and gently place it in you are good. You will need new Thermal paste to re-do your heat sink as well.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543165
nah not really maybe the 980 ti is similar
Behold the power of Chuck Norris the forbidden one.
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543176
I've seen benchmarks of the 980, 980ti, 1060, and the 1070. The 980 seems to be in between the 1060 and 1070. And the 980ti seems to be in between the 1070 and 1080. Or I may be wrong, I saw the benchmarks a while ago.
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543197
Yes it is..use userbenchmark.
980 is not very similar to 1070..i would say its 80% close the performance to 1070. but its older so generally 1070 its better in overall that is unless u are doing something other than gaming and doesnt care about power consumption or driver update.
and 980 ti is like 98% well that GPU is an old beast and still kickin until now.
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-980-vs-Nvidia-GTX-1070/2576vs3609
http://gpu.userbenchmark.com/Compare/Nvidia-GTX-980-Ti-vs-Nvidia-GTX-1070/3439vs3609
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543202
xD Old beast, jesus it has only been 2 years
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543211
980 is 100% sufficient for gaming still. Ya_Mi seems to be on the sour side this morning.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543216
Well if u look back..observe what we have achieved in the last 2 years..
Everything is evolving like crazy..the most noticeable part is the power consumption of course.
just take a look at how efficient modern gpu nowadays.
So Imo for a gpu 980 ti is consider to be old.
But as i said that beast is still kickin and if u dont care about power consumption & driver update that gpu can still kick AAA title in the ass.
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543224
No don't use that trash, go by independent reviews comparing average, max and minimum FPS and most importantly frame times ideally at the resolution and games you play, for me I played GTAV and Rise of the Tomb Raider on 2x 970s (very slighter ahead of 980ti) @ 1440P and was looking at the Palit 1080 Gamerock Premium as it was pretty cheap and I could get a water block for it. These are the reasons I stay away from those sites
http://www.kitguru.net/components/graphic-cards/zardon/palit-gtx-1080-gamerock-premium-edition-review/16/
@WhatComesAround
If you look there the 980ti is no where near a 1070
http://www.kitguru.net/components/graphic-cards/zardon/palit-gtx-1080-gamerock-premium-edition-review/19/
and again
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543249
@WhatComesAround
and again
Well yes because userbenchmark is all about computing power and render not games benchmark well they never include games actually. userbenchmark is not trash gpu/cpu boss are.
If this is about games then yeah i agree u cant compare GPU based on their specs for video games or i should say shouldn't.
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543279
Uhh actually, I would say advancements in technology has been slowing down recently compared to 5-7 years ago I believe. Further advancements in regular computing is becoming physically restricted, which is why quantum computing is of great interest right now.
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543327
Well because the more advance it is the more complicated it gets or its just because of money behind the reason of small improvement each gen looking at you intel. tick tack tock my ass.
But who knows what will came up next..
https://linustechtips.com/topic/754536-cpu-upgrade-questions/#findComment-9543348
