should i get XF140 fan for cryorig h7?
Blackhole890
so i wanna replace the original fan and i know that the original one is 120mm vs 140mm so thats why im asking here if i can replace it somehow
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
It's pretty obvious that you can't unless you do some modifications to it
but does it comes with 140mm brackets?
What?
Cryprig's 140mm fan uses 120mm screw holes. The one i am talking about is completely round. If your 120mm is square then it will work just fine
It won't be much if any better than 120mm fan. It will cool more mobo components, but those are usually fine with normal 120mm fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
well, im just getting that for aesthetics :P
w-what? s-s-so i can install i-it on my cryorig h7?
qf120 is what comes as stock and i want to install xf140... are you sure that it will fit?
It looks like xf140 has 120mm mounting holes, so year.Oterwise you'd need to use zipties or other ghetto way.
1 minute ago, Blackhole890 said:
what do you mean?
H7 has 120mm mounting. If fan doesn't use 120mm mounting, included brackets won't work.
but in this case, do you think that it will or not? xD
I have nor cooler or fan. So I can't say for sure. I do have cooler which uses 120mm brackets and 2 150mm fans attached with those brackets.
just checked it will work just fine :-)
WAIT WHAT? WHAT DO YOU MEAN THAT WORKS FINE??? DOES IT FIT??? *heavy breathing*
YES :-)
5 minutes ago, cj09beira said:
YES :-)
WHERE CAN I SEE THE PROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF???!!??!?!?!?1
if you go to cryorig's site you can look at photos for all the products and the fan you have is a 120mm fan with 120mm holes while the xf140 is a 140mm fan with 120mm holes and by looking at the height of the cooler it will be a bit taller than the cooler but should work fine
but the problem is that im not sure if xf140 will work with the h7 brackets...
What is so hard to understand in that? Fan uses 120mm mounting, brackets are for 120mm fans. ANY 120mm fans.
Look well to the photos it will work as long as the depth of the two fans are similar
well, i got the feedback from cryorig that it wont work together, and you guys insist that it will work so lets cross our fingers because its shipping xD
I plan to buy one also. Update us when it arrives
follow me coz i will forget to reply you probably. Maybe when it arrives, i will make a review or smth like that
