Ethernet cable routing
9 minutes ago, silraks said:So this a bit weirder post, but I need some help and suggestions to improve my network.
This is the current setup. I have a set-top box which requires a different port a runs on a powerline adapter. There also is a smart tv/xbox and another tv box. Currently it runs on two long ethernet wires through the room which looks crappy and is a bad solution (outer shell of the cables is punctured in multiple places, but not deeper). To make matters worse, there is only one female port. To use one or the other I switch the cable at the port. The use cases are not demanding on speed and our connection is also bad. The wifi connections on the tv and xbox are pretty unreliable.
One solution would be to buy a 1 input and 2 output powerline adapters, but could there be any alternatives?
Thanks for your help!
You can just have a single powerline adapter from your router to the main TV area and use a switch to allow for more ports and connections since you also have an xbox and smart TV.
