Need Help. Codeigniter 3.1.3 & SQLServer Connection
By
RandyPR
in Programming
in Programming
Solved by C2dan88,
PHP is not recognising the sqlsrv_connect function. To use the sqlserv_*() functions you need to enable the sqlserv PHP extension
Try
http://bendustries.co/wp/setting-up-xampp-to-work-with-mssql/
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
