PC randomly freezes upon boot help
so i finally got my pc built and ive been gaming all day when i turned it off due to going away for a bit. now, as soon as i boot into windows it freezes up, or sometimes when i click on anything. it keeps doing this, ive booted multiple times and it keeps doing this. should i maybe clear the cmos? also the bios works, but windows freezes
https://linustechtips.com/topic/754168-pc-randomly-freezes-upon-boot-help/
Yes, clear CMOS and try again... could be an OC problem if you have one? or a driver fault even, but try clearing CMOS first.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
i decided to boot into safe mode first. i dont have an oc on my cpu but maybe my gpu but that shouldnt do anything
safe mode worked but not when i did it again after disabling startup processes. i just cleared my cmos via battery removal
Reinstall Windows
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
1 minute ago, Ethan Meskin said:
its a driver or overclock issue- it works on my mobos integrated graphics but not with my GPU
Yes. So if you reinstall Windows this issue will be resolved :)
itll be a pain- is there another way?
Boot into safe mode and uninstall drivers with DDU. Then boot into normal Windows and reinstall GPU drivers.
I'm not quoting you to shitpost or anything, just highlighting where you went wrong... if you ever have problems with BSOD, first rule of thumb is take off ANY OC settings. Doesn't matter IMO that it's GPU OC, because as you found out it was that which was making the problem. Even if you think it might not be the problem, do it anyway. That way you have a level playing field again from which to begin troubleshooting further if needed. I'm not saying this to ridicule you or anything, we have all been guilty of having a bias of opinion and not doing something even though we should, at some point in out lives..I know I have, so don't worry about it :)
Main thing is you got the problem fixed that was causing your freezing problem, and can learn from this. Glad you got it sorted mate.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
