would 1200w be enough to power two systems off one power suppy both systems custom watercooled.
specs
CPU- 7700k
GPU- gtx 1070
remember this is for two systems off one psu and i want overclocking headroom.
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/753965-enough-power-for-system/
Just now, zMeul said:
1.2KW is way overkill even for two systems
im using the one psu for both systems.
CPU-I7 4790
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537647
You'll be fine.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537649
yeah, I read
one system will go 300-400W with OC
really with a custom loop and all
CPU-I7 4790
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537652
1 minute ago, zMeul said:
custom loops don't add that much power draw
you have what .. a pump - 18W
ok cheers for the help.
CPU-I7 4790
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537658
why do you need to run two systems off one PSU though?
where will you get the second 24-Pin cable?
isn't it just easier to get 2 PSUs
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537676
Mate. phanteks mini xl can hold two systems they also provide a power splitter to run two systems off one psu. and it would look dope af.
CPU-I7 4790
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537720
Really!? I had no idea. awesome.
850W is enough IMO, so a 1000W or more power supply is nothing at all to worry about.
Laptop:
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537733
i know i found out about this case recently. when i saw all the potential it has i had to have one. so begins the save up for the case and dual system build that or a 5 rad watercooling build.
CPU-I7 4790
https://linustechtips.com/topic/753965-enough-power-for-system/#findComment-9537740
