Cablemod widebeam leds in a display case???
10 hours ago, Wolf_Lbh said:So I'm rocking this display cabinet: https://www.amazon.com/dp/B00275FL5A
And it has plenty of room but it isn't illuminated very well. Given that it is metal I was thinking I would just put some 60mm white magnetic widebeam led strips on the underside of each shelf. But to get this project working I need 2 things:
1) A cable to daisy chain one led strip to another a few feet long.
2) A cable that will plug into the first led strip and an outlet or adapter that plugs into an outlet on the other end. It would be powering 5 60mm widebeam led strips total if that has any impact.
You can get LED kits online for a good price and wire them up for a lower cost with brightness control. However if you want to use the Cablemod stuff that would be same kind of setup. You will need extensions such as the ones below and the 4 pin to D.C. Barrel adapter to plug into 12V power.
