I currently have a HIS R9 380 IceQ X² OC 2GB and I want to up grade it.
My choices are
MSI GeForce GTX 1060 0 GAMING X 6G - $250 (no tax free shipping)
=OR=
ASUS Dual OC Radeon RX 480 Graphics Card - $236 (no tax free shipping)
Current PC Specs are:
Processor: AMD FX-6300 6 Cores 3.5 GHz
Motherboard: Gigabyte 990FXA-UD3
Memory: 8GB DDR3 (2x4GB sticks)
Graphics Card: HIS R9 380 IceQ X² OC 2GB
Storage: Toshiba 2TB
Power Supply: CX600 80 PLUS Bronze 600W
Operating System: Windows 10 Home 64-bit
A few questions too:
Will any of the GPUs get bottlenecked because of my processor?
Are any of the GPU's capable of running GTA V on ultra 60 fps?
Which one is better for the long run?
Which one has better bang for your buck?
Which one is overall better?
If I get the AMD card can I run a crossfire through my current one?
Which GPU is louder?
Which GPU is cooler?
Is there a better GPU than my current choices?
https://linustechtips.com/topic/752903-need-help-choosing-a-gpu/
My choices are
=OR=
don't upgrade the 380 is fine rather a new cpu or if you want a gpu the 480
https://linustechtips.com/topic/752903-need-help-choosing-a-gpu/#findComment-9525955
