Well I used prime95 to check my cpu, and boom it hit 100 c. I do live in texas so it's pretty hot here.
But I checked on aida64 and my cpu multiplier kept changing. I don't know if this is normal.
A few seconds after
CPU - i7-4790k
GPU - MSI 980 Ti
Mobo - MSI Z97 Gaming 5
Memory - 32 GB DDR3
Storage - 3.4 TB
Full List : https://pcpartpicker.com/list/sPgN8d
https://linustechtips.com/topic/752016-cpu-multiplier-keeps-changing/
7 hours ago, PenPoint said:
Intel Turbo Boost technology, that's why the multiplier is constantly changing to meet the best efficiency possible.
How can I turn it off? (If possible)
7 hours ago, Dutch-stoner said:
Seriously, when your pc is at idle/doing nothing, the multiplier goes down, because the CPU power isn't required. As soon as your PC has to do something, it will go back up.
Sadly, i wish it was that easy, but it is not.
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
1 minute ago, Dutch-stoner said:
@PenPoint Not sure about "intel turbo boost tech", but I do wonder. My AMD system without turbo will have an multiplier that goes from 8x to 35x, and with turbo on, up to 45x. It's how things work.
In case of AMD, it's called 'Cool'n'Quiet'.
It's part of the built in power saving features. If you want to turn it off, change your Power Plan in Windows to High Performance.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Either you have an overclock set or Intel Turbo Boost is active. You can disable this through the BIOS of your motherboard. The button to get into the BIOS when your PC boots up is sometimes different from motherboard to motherboard, but I think most of them will all respond to the Delete key.
You should also look into a better cooler if it's that bad in my opinion. The Cryorig H7 or Coolermaster 212 Evo are good choices for budget options.
A few seconds after
yes it's normal, your CPU is trottling to prevent you from destroying it.
100c is incredibly hot and it's not normal make sure your CPU cooler is well seated and that you used a proper amount of thermal paste.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
3 hours ago, Kloaked said:
I don't know for sure if it's just my cpu cooler.
3 hours ago, i_build_nanosuits said:
 Ive looked online and people say its normal for haswell cpus to get this hot in prime95
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
100c is not normal for a 4.2ghz i7-4790k. Either the thermal paste dried up acting like a insulator or your cooler isn't fully seated on the CPU. Either way, I would remount the CPU cooler with fresh thermal paste and be sure to check all the case fans for obstructions. Then redo your prime95 testing to compare.
I7-7700k@5.1ghz + 1080ti @ 2050mhz + 32gbs Ram + 2TB SSD = CSGO
i7-6700k@4.9ghz + 980ti @ 1501mhz + 16gbs Ram + 1 TB SSD = Backup
i7-3770k@4.8ghz + 680 4gb + 32gbs Ram + 500gb SSD = Retired/Office work
Okay ill try that
CPU - i7-4790k
GPU - MSI 980 Ti
Memory - 32 GB DDR3
Storage - 3.4 TB
