There are many great gaming mice out there. You could go with the Logitech G600 if you are interested in a lot of macro keys. http://www.amazon.com/Logitech-Gaming-Mouse-Black-910-002864/dp/B0086UK7IQ Or the Cosair M60 http://www.amazon.com/Corsair-Vengeance-Performance-Gaming-CH-9000001-NA/dp/B005QUQP76 (There is also the more expensive M90). Or lastly you could get a R.A.T. 5 http://www.amazon.com/Mad-Catz-R-A-T-Professional-Gaming/dp/B003DKJ44C (If you prefer wireless then the R.A.T. 9).
Been using a G600 (White) myself. I can personally recommend it to anyone looking for a 'gaming' mouse.
It also has a massive-array of bind-able buttons! (If you're into that.)
https://linustechtips.com/topic/752-need-help-on-gaming-mouse/#findComment-9430
I am still a huge fan of the Logitech G500, which is what I am currently using and have been for 2 years. However, the G700 is also fantastic, and I would say is a general improvement over the G500.
If you play a lot of MMO's then you would probably like a lot of macro keys. For this, get a G600 or a Razer Naga. I don't normally recommend Razer products, as you are often paying solely for the brand, and getting an OK product for your money, but the Naga is one of my favorite MMO mice of all time, and it also looks pretty cool.
The R.A.T 7 and 9 are also really good, and although they look a bit gimmicky they are hands down some of the most comfortable mice I have ever used.
https://linustechtips.com/topic/752-need-help-on-gaming-mouse/#findComment-9636
I can recommend Roccat mice for long term use. My Kone mice just died after 3,5 years of decent gaming usage. And it's actually still working but buttons are not working correctly. So I can say it lasted atleast 3 years. Now I have new Roccat Kova+. It has some hw and software issues but nothing unreasonably.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/752-need-help-on-gaming-mouse/#findComment-10130
Anything Steelseries, very reliable brand and make great mices.
Steelseries Sensei, Sensei Raw are all mices that come to mind.
a linus unboxing.
more info @ http://steelseries.com/us/products/mice/steelseries-sensei-raw (cheaper at your nearest retailer / etailer)
https://linustechtips.com/topic/752-need-help-on-gaming-mouse/#findComment-14528
Having recently been looking for a gaming mouse, I found this beauty.
The 8200 DPI is a bit over the top but the customisability of colours and macros are overwhelming.
Its a bit pricey, but if you can afford it defiantly worth the money.
I highly recommend it.
System Spec
Corsair C70 Black -- Intel i7-4770K @4.2GHz -- Corsair H100i --Gigabtye Z87X D3H -- Corsair Vengeance Pro 8GB 1866MHz (Blue)-- Sandisk Extreme SSD 240GB -- WD Caviar Black 2TB 7200rpm -- EVGA GTX 780 with ACX Cooler -- Corsair HX750
https://linustechtips.com/topic/752-need-help-on-gaming-mouse/#findComment-17158
