use https://pcpartpicker.com/list/ to make a list of whatcha want
If you want a suggestion of the whole thing
PCPartPicker part list: https://pcpartpicker.com/list/pWGPGf
Price breakdown by merchant: https://pcpartpicker.com/list/pWGPGf/by_merchant/
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($329.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus MAXIMUS IX HERO ATX LGA1151 Motherboard  ($217.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($119.88 @ OutletPC)
Storage: Sandisk X400 512GB M.2-2280 Solid State Drive  ($159.00 @ B&H)
Video Card: MSI GeForce GTX 1060 6GB 6GB GAMING X Video Card  ($259.99 @ B&H)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($69.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($77.88 @ OutletPC)
Total: $1259.60
Generated by PCPartPicker 2017-03-13 20:02 EDT-0400
I'm not very good at making lists though, wait until someone else comes along
https://linustechtips.com/topic/751929-my-first-build/#findComment-9514925
11 minutes ago, adamshaffer69 said:
I need to know how much what I want is all together and what tools ill need
what I want
intel core i7
gtx 1060
16gb of ram
512gb ssd
1tb harddrive
give me good suggetions for other thing like the motherboard and stuff
Thankyou!
Hey man, if you want I can make you a nice build PC Part Picker if you'd like. However I would like to suggest to you the AMD Ryzen. They just released with new processors and the 1700 performs on par for most things and even better for multitasking in comparison to the Intel Core i7. Even if you have the spare money a 1700X or even 1800X would be perfect due to their ability to overclock themselves whenever they need to for handling a larger load. Just basically the 8 cores would provide a better overall use for the CPU. If you need anything else contact me and I'll be glad to help!
https://linustechtips.com/topic/751929-my-first-build/#findComment-9514967
I know I'm not really into amd ryzen and I would really like to build it myself thanks though
https://linustechtips.com/topic/751929-my-first-build/#findComment-9514995
Total: $1259.60
I'm really bad which is why I went here thanks!
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515000
35 minutes ago, Ultra_Man52 said:
woah bronco slow down, this isn't really a good build. I would really go with an i5 and 1070 if I were you, but if you are dead set on i7 then I would say this is decent
yes I am really set on an i7 what do you think a i5 build looks like though
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515147
what I want
intel core i7
gtx 1060
16gb of ram
512gb ssd
1tb harddrive
Thankyou!
what's your budget? are you doing gaming only or are you also doing streaming/editing/rendering?
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515521
Just now, adamshaffer69 said:
I am also going to edit and render my budget for everything including keyboard mouse and everything 1.,500
ok, so you need a monitor, keyboard, mouse and OS too?
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515538
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515558
3 minutes ago, adamshaffer69 said:
yeah
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($316.98 @ Amazon)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock Z170A-X1 ATX LGA1151 Motherboard  ($91.00 @ SuperBiiz)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($47.92 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.00 @ Jet)
Case: BitFenix Comrade ATX Mid Tower Case  ($27.99 @ NCIX US)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.90 @ B&H)
Monitor: Dell S2417DG 23.8" 2560x1440 165Hz Monitor  ($410.30 @ Amazon)
Keyboard: G.Skill Ripjaws KM570 Wired Standard Keyboard  ($64.99 @ Newegg)
Mouse: AZIO EXO1 Wired Optical Mouse  ($6.99 @ Amazon)
Total: $1466.83
Generated by PCPartPicker 2017-03-13 22:22 EDT-0400
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515576
get your OS from reddit for $20-30.
CPU: AMD RYZEN 7 1700 3.0GHz 8-Core Processor  ($328.89 @ OutletPC) will be much better than the 7700k in rendering and editing.
CPU Cooler: Enermax ETS-T40F-BK 76.0 CFM CPU Cooler  ($40.88 @ OutletPC) contact enermax for am4 mounts.
Motherboard: Asus PRIME B350-PLUS ATX AM4 Motherboard  ($99.99 @ B&H)
Memory: Patriot Viper 4 16GB (2 x 8GB) DDR4-2800 Memory  ($99.99 @ Newegg)
Storage: ADATA Ultimate SU800 256GB 2.5" Solid State Drive  ($74.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.38 @ Amazon)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($53.00 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($46.89 @ Newegg)
Monitor: Acer GN246HL 24.0" 1920x1080 144Hz Monitor  ($188.99 @ B&H)
Mouse: Corsair M65 PRO RGB FPS Wired Optical Mouse  ($39.99 @ Newegg)
Total: $1464.86
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515577
Total: $1464.86
sorry I don't want amd :/
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515586
Total: $1466.83
the only thing missing is ssd ! very nice though
https://linustechtips.com/topic/751929-my-first-build/#findComment-9515590
