psu modding Modding 2 x 6 Pin PCI-E Into Single 8 Pin?
The SENSE wires are connected directly to GROUND in the power supply (the black wires in the connectors).
If you wanted to, you could grab a soldering iron and solder a wire across all those non-12v pins in the PCI-E connector on the video card and then you'd be able to plug your 6pin pci-e connector in the 8 pin connector and it would work just fine.
The video card basically does this:
Is a connection to ground on Sense A pin ? If yes, we have at least a 6pin connector plugged in, so we're allowed to take up to 75w through this connector.
Is there also a connection to ground on Sense B? If yes, that means we can take up to 150 watts through this connector.
Some video card manufacturers had this idea in mind to use same base design with a 6pin pci-e connector and block overclocking of the video card, and release same design with 8pin pci-e connector and enable overclocking for more profit ... that's the whole idea behind these separate sense pins.
When the standard was made, PSU manufacturers wanted to make connectors with 4 ground and 4 12v wires but they had to compromise when some video card manufacturers wanted this. (oh and another minor reason for refusal was similarity with eps, they hoped black wires on one end would prevent confusion)
