Hi guys.
I am in desperate need of help. Today I installed a second SSD on my pc. Didn't think much of it as it's nothing special. I turned it on and now all my fans are being really weird. The radiator and exaust fans(corsair ml ones) keep flickering, king of like they aren't getting enough power or are running two low. The front ones run for abit and then come to a stop.
Im really stuck and don't know what to do. I've been having so many issues lately I feel like giving up. Everything was fine yesterday and all I did was install another SSD.
Thank you.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/751801-desperate-help/
15 minutes ago, Nosfy said:
Hi guys.
Thank you.
do you still have the issue if you unplug the ssd?
https://linustechtips.com/topic/751801-desperate-help/#findComment-9513499
Yeah. I really don't understand.
https://linustechtips.com/topic/751801-desperate-help/#findComment-9513512
seems very strange. I've never encountered that kind of issue myself... Unless the ssd somehow broke something in your psu...
Everything else seems fine so hopefully it's not the psu.
https://linustechtips.com/topic/751801-desperate-help/#findComment-9513540
@MimigaKing I think the pwm controlled got busted somehow. Fans and everything else is running fine. Only thing now is windows is not recognizing the second SSD.
https://linustechtips.com/topic/751801-desperate-help/#findComment-9513737
