Been planning a build for awhile and since the 780 recently dropped in price I did some research. I was originally going to get the 780 Lightning but Newegg reviews and OCN Owner's Club members complained that the 780 Lightning uses Elipda memory modules, which have very bad overclocking capability. I had a brief look at the 780 Classified from EVGA, and in a certain number of cards Elipda memory modules were used to meet demands. Though EVGA Reps have said that they are using good OC'ing memory now (Samsung) it is still not 100% guaranteed you'll get Samsung memory - however Lightning's have never used Samsung, whereas you can get a Classified with Samsung.
If given the choice, which would you go for? I really do want to get the most out of the card, and I don't think the 780Ti is a good value in my opinion.
https://linustechtips.com/topic/75133-780-brand-help/
I would go with either of those. I really like ASUS Direct CUII cards, but EVGA has better warranty. Don't know much about MSI. I would recommend EVGA.
I've never really heard of Asus cards in respect to really good OC'ing, only noise levels. Some guys on OCN were able to get 1300-1400MHz in the core. On air. Holy jebbus.
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029407
If you are overclocking go with anything with samsungs but make sure you can get a full waterblock for it !
I like direct CU2 cards by asus though, they are really cool and work well
Well, that's what Im trying to figure out, will an EVGA Classified 780 come with Samsung memory?
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029412
Evga Classified..
*Recently dropped in price.
*Powerhouse card
*Runs cool and quiet
*Custom PCB
*3 year warranty
*Comes with a bunch of free games
*EVGA's great support
Cpu 3970x, Ram Corsair Dominator 32Gb, Case Corsair 900D, Storage Raid 0 Samsung 512Gbs 2 ssds, 1TB WD Black Drive and 2Tb WD Black Drive, Psu Corsair 1200watt, Display Samsung 27inch 2660by1440, Cooling 4 alphacool radiators, 13 fans, Ek rez, 2 pumps, Keyboard Corsair K70, Sound Sennheiser 363d
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029429
Cant go wrong with EVGA...
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029433
Evga Classified..
*Powerhouse card
*Custom PCB
*3 year warranty
But will it come with Samsung memory? I know it was stated once that Samsung memory is now back on these cards but I really have no clue.
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029446
Just don't OC the memory. All the performance comes out of the core anyways.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029463
Really, memory OC has a very minimal impact on performance until you hit 4k, it should play a very little role in choosing a card.
Yep thats true, plus what res are you running on your display??
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029481
eVGA really is the brand to go with when it comes to NV cards. Their warranty and support are amazing.
9900K  / Noctua NH-D15S / Z390 Aorus Master / 32GB DDR4 Vengeance Pro 3200Mhz / eVGA 2080 Ti Black Ed / Morpheus II Core / Meshify C / LG 27UK650-W / PS4 Pro / XBox One X
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1029575
evga
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1030028
I usually go with EVGA and went never wrong with it!
My very first GTX780 SC (reference design) had a problem and I called EVGA. Amazing service level. No BS talking they sent me right away an UPS shipping letter and I got the new card within 8 days, which is absolutely great! All you have to do is register your card on their side and you are fine.
They even hold the warranty if you damage the card with water cooling. All that they require (so I was told on the phone, cause I asked them about warranty policies) is that the card arrives in one piece and the standard heatsink must be on it.
Elpida Ram aren't that bad. You get the most power out of OC'ing the core and the classified is very good for this since it has 2 8-pin power connectors and a custom pcb.
GreetZ Naj
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1031896
Especially where the memory probably has a 5GHz effective clock...
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/75133-780-brand-help/#findComment-1031939
