I am running 9 fans in the phanteks evolv atx glass case with maximus ix formula mobo. Not sure what to connect to case headers, or if i should be using case fan headers at all. I've read I could also purchase molex adapters and connect straight to psu? Just looking for some helpful tips since research hasn't gotten me anywhere this time. Thanks!
https://linustechtips.com/topic/751205-9-fans/
why do you even need 9 (!!!!) fans?
I probably take the best 3 for the case, 2 in the front, 1 in the back and take the rest out of the system.
Most times the motherboard fan headers are the best bet for controling fans.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/751205-9-fans/#findComment-9507178
nobody needs 9 fans! lol purely aesthetics, i wanted to experiment and have more of an enthusiast build this time around. and yeah if i only had a few fans i'd just use the mobo headers. but now I'm not sure if I need to buy splitters, molex adapters, plug straight into psu? all things I've read about but no idea what my approach should be
https://linustechtips.com/topic/751205-9-fans/#findComment-9507226
What fans are you trying to control?
https://linustechtips.com/topic/751205-9-fans/#findComment-9508769
8 hours ago, Pidgey said:
6x hd120- 1 back exhaust, 3 top exhaust,2 front intake pulling rad, 3 ml120- front intake pushing rad
A 4pin pwm splitter or hub to your cpu_fan header would probably be your best option.
Where are you shopping/located? Budget?
https://linustechtips.com/topic/751205-9-fans/#findComment-9513138
I actually just ended up using the 4 fan splitter on the kraken and the case header on the back and plugged it into h-amp on the mobo. only downside is there is no individual control of fan speed
https://linustechtips.com/topic/751205-9-fans/#findComment-9518481
