Hi all
I have 2 questions. Im planning on getting the Cooler Master Hyper 212 evo, and i have the bitfenix nova. In my case manual it said there is room for a 160mm cooler but the 212 evo is 159mm.
Will the 1mm that is left cause any problems ?
My second question is how much better is the Evo than the intel stock cooler in temps, noise.
tnx
https://linustechtips.com/topic/751160-will-it-fit/
You should be just fine in space, noise, and thermals with the 212 evo over the stock intel.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506699
Yes, it will fit. There's one installed in this review (it's not an EVO, but they are the same height) http://www.legitreviews.com/bitfenix-nova-mid-tower-pc-case-review_175078/4
Bitfenix-Nova-Build-Hardware-Install-645
Significantly better in terms of temps, quite a bit better in terms of noise http://www.hardwaresecrets.com/cooler-master-hyper-212-evo-cpu-cooler-review/6/
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506700
The case is 1mm bigger, not 1mm too small. It should fit.
Edited by Pepi28
wording
MAIN RIG | AMD R7 1800x @ 4.0GHz [cooled by Corsair h110i] | Zotac 1070 founders | Corsair Dominator Platinum 2x8gb |
| ASUS crosshair IV hero | Samsung 960 evo m.2 | Seagate 1TB + WD blue 2TB| Corsair HX750i | Phanteks evlov atx TG |
LAPTOP | HP zbook Workstation | Intel i7-4710 HQ @ 2.5GHz | 8gb ram | NVIDIA Quadro k1100m | 250gb + 250gb Crucial SSDs |
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506727
Thanks but i clicked on the lin (hardwaresecrets) but its empty...
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506731
What is your CPU?
If your CPU doesn't support overclocking then getting an aftermarket CPU cooler is a waste of money.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506782
The Evo wipes the floor with the stock cooler in all aspects.
However if you are not going to overclock, the stock cooler is fine.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506784
6 minutes ago, LinusTechTipsFanFromDarlo said:
What is your CPU?
i5 6400, are you sure about that ? Sorry but my pc is new and my cpu gets just a bit under 60 when im gaming
Really ?
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506800
The Cryorig H7 is better than them both, and doesn't look super ugly.
Edit: Never mind, you don't need it if you aren't overclocking. 60C is plenty cool.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506806
What is your CPU?
Whilst it provides the most benefit when overclocking, it's still much quieter than stock when not overclocking and it will still lower temps even on non clocked, so I wouldn't say it's a waste of money
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506807
Just stick with the stock cooler as your CPU doesn't support overclocking.
زندگی از چراغ
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506808
60C is fine for a CPU.
The maximum safe operating temperature for most modern CPUs is usually 105C.
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506809
Strange, it works for me.
Here's a screenshot of their results table, Intel stock and the 212 EVO are outlined.
EDIT: Try this link http://www.hardwaresecrets.com/cooler-master-hyper-212-evo-cpu-cooler-review/
https://linustechtips.com/topic/751160-will-it-fit/#findComment-9506814
