Unknown problem need help
Go to solution Solved by WorlofDead,
The problem was the LCD wire it was damaged and messing with the charging so just change the wire and it will work
Ok so my problem is what happened to me 2 days ago so normal day and so I go on my laptop a lenovo g570 and start watching Linus tech tips I decided to go downstairs so unplugged the charger from my laptop and went downstairs after like 6 vids my I slightly close my screen and then it goes green and the a purple strip fly by my screen and the power goes off and I think oh it must be out of battery so I go to plug it in and it starts to beep so but doesn't charge so I try the 60 sec thing but that doesn't help so I start to listen to where the beeps are coming from and it was from the adapter but the adapter was working fine 40 minutes ago
So here are the things u should know about my laptop:
Used to have a i3 processor I changed it to a i5 about 3-4 weeks ago
The hinges are broken so every time I opened it I slightly damaged the LCD wire to the point where u cant change the brightness and it's stuck at the highest brightness so it has to stay open at a 90-94 angle in order to not shut off or turn the screen green
That's all the things u need to know ask me if u need more info
https://linustechtips.com/topic/751037-unknown-problem-need-help/
Wow it's like the G570 series have hinge design problems. The one I my friend gave me also has a broken hinge that restricts screen position to 90 degrees unless I use brute force.
Anyways, have you tried turning on the system without the power adapter plugged in? Looks like yours just caught the ghost.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Yes it's not turning on at all I asked a couple of friends and they said it could be the motherboard or the adapter is broken
Is the power button lighting up and just turning off? Mine does that as well.
No there is no power
And it used to do that when I changed the processor I moved the wire to a place so it can turn on when ever I open the laptop
