I need some help with Unity player movement
So I'm trying to make a Zelda-like top down RPG and I need a way to disable diagonal movement. I'm using a RigidBody to control the character. Here's the script, yes I know animations are incomplete.
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
public class PlayerController : MonoBehaviour {
	public float moveSpeed;
	private Animator anim;
	private Rigidbody2D rbody;
	// Use this for initialization
	void Start () {
		anim = GetComponent<Animator> ();
		rbody = GetComponent<Rigidbody2D> ();
	// Update is called once per frame
	void Update () {
		if (Input.GetAxisRaw("Horizontal") > 0.5f || Input.GetAxisRaw("Horizontal") < -0.5f )
			//transform.Translate (new Vector3(Input.GetAxisRaw("Horizontal") * moveSpeed * Time.deltaTime, 0f, 0f ));
			rbody.velocity = new Vector2(Input.GetAxisRaw("Horizontal") * moveSpeed, rbody.velocity.y);
		if (Input.GetAxisRaw ("Vertical") > 0.5f || Input.GetAxisRaw ("Vertical") < -0.5f)
			//transform.Translate (new Vector3 (0f, Input.GetAxisRaw ("Vertical") * moveSpeed * Time.deltaTime, 0f));
			rbody.velocity = new Vector2(rbody.velocity.x, Input.GetAxisRaw("Vertical") * moveSpeed);
		if (Input.GetAxisRaw ("Horizontal") < 0.5f && Input.GetAxisRaw ("Horizontal") > -0.5f)
			rbody.velocity = new Vector2(0f, rbody.velocity.y);
		if (Input.GetAxisRaw ("Vertical") < 0.5f && Input.GetAxisRaw ("Vertical") > -0.5f)
			rbody.velocity = new Vector2(rbody.velocity.x, 0f);
		anim.SetFloat("MoveX", Input.GetAxisRaw ("Horizontal"));
		anim.SetFloat("MoveY", Input.GetAxisRaw ("Vertical"));
Did my post help you? Then make sure to rate it!
Check out my post on symbolic links! || PSU ranking and tiers || Pokemon Thread
https://linustechtips.com/topic/750758-i-need-some-help-with-unity-player-movement/
you could do an if statment comparing the vetical axis and horizontal
something like
if (mathf.Abs(Input.GetAxis("vertical")) > mathf.Abs(Input.GetAxis("horizontal")))
//vertial movement code
//i would use
transform.Translate(Vector3.forward * Time.deltaTime * Input.GetAxis("vertical"))
}else{
//horizontal movement code
transform.Translate(Vector3.right * Time.deltaTime * Input.GetAxis("horizontal"))
THE RIG
CPU: i7 3770K @ 4.9 COOLER: Kraken X61 MOBO: Z77 Sabertooth RAM: Vengeance 16gb @1600 GPU: ASUS ROG Strix GTX 1080 PSU: EVGA Supernova G2 850w SSD: 850 Pro 256Gb    CASE: B/W phantom 410 AUDIO: Kraken 7.1 Chroma MOUSE: Death Adder Chroma KEYBOARD: Black Widow Chroma MONITOR: Triple 23" Apple Cinama Displays   VR: HTC Vive & Oculus Rift DK2
