You need do reinstall of Windows on your SSD, just remember unplug your HHD when install windows and replug after install is finish when it boots into windows. I presume your SSD is new so after install windows you can copy files over to new SSD and just delete old windows files from HDD.
Magical Pineapples
https://linustechtips.com/topic/750562-really-need-help/#findComment-9500459
Why do you want to unplug the HDD?
During windows setup installation, just select the SSD as the install medium... I've done this many many times and not once have I had to unplug anything. Seems overly complicated to me. It would only be a problem really if the OP also had a hard drive with windows already installed on it, and was experiencing problems with booting the correct drive.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/750562-really-need-help/#findComment-9502042
If you have HDD plugged, windows will install window files onto those drives which mean you need all your drives for window to boot up. It much better having window install onto on drive which allow you remove other drives without causing problem with your windows.
Magical Pineapples
https://linustechtips.com/topic/750562-really-need-help/#findComment-9504570
