Where do i connect the Gpu power cables with a fully modular Psu?
Amateur Gamer
Go to solution Solved by Al Hoff,
6 minutes ago, Amateur Gamer said:
Where do i plug those in?
There are a lot of options
the 5 circled-- any of them no special order will work.
Hi everyone!
So this is an extremely noob question i know but i don't know much about today's hardware.
I bought a Corsair Rm850x a fully modular Psu and i'm about to buy an Msi Gtx 1070 Quicksilver.
My problem is that i have all these cables and i'm not sure which ones i'll need and where to connect them to the Psu itself.
From the images i saw the msi gtx 1070 Quicksilver has a 6+8 Pin connectors so i know that much.
I hope that my question was understandable... My English isn't the best but at least it's enough to get by.
Question is clear. You should have a set of PCIE cables in the packet of cables that came with your PSU. They will more than likely be 6+2 pins so just look for them in your packet of cables
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
