Hiho people,
I did RAID 0 6 months back, and it failed for no reason recently. I sent my SSDs 2x to Kingston and one turned out to be fake (papa bless E-Bay), and Kingston said that I need two SSDs with the exact same firmware, but I bought one on Amazon and they're still different after receiving a replacement. Will I be okay with two different SSDs in RAID 0? (I'm getting a refund for the fake one) Will the speeds be decent or should I just use the drives separately?
(It is impossible for me to get an identical drive to the one I had received from Kingston because no one around sells the Kingston V300 ones and online sellers refused to specify the firmware which is literally written in the front of the package)
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/749784-raid-0-fail-help/
I would take the refund and buy something other than a V300 (Kingston did a bait and switch with the NAND, making them significantly slower than the first revisions).
RAID 0 is a bad idea in general. Use the drives separate, that's what I'd recommend.
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491556
Well, it'd look messy to have 4 drives on my PC. I wanted RAID for quicker boot and stuff. I can return only one so I'd still be stuck with 1x V300 so I have no choice to keep it.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491601
RAID 0 will likely slow down or negate any speed benefits for booting. The RAID controller has to initialise and the array needs to be established before the OS can be loaded. Without RAID, these steps don't need to be performed. Transfer speeds may increase, but that's provided you have other drives that can match the RAID 0 array in terms of speed. If not, you're just getting the speeds of whatever drive you're transferring to/from. Loading into RAM will be faster, but there's not too many applications where the speed benefit will gain you much, other than slightly lower load times.
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491743
What's your suggestion in this case? I bought the SSD for esthetics as well. Should I just install it on one SSD and have 2nd SSD used for something else?
I had a laptop with 120SSD in RAID 0 and it was booting in literally seconds, I know it wasn't an X99 system but still, my X99 system takes one minute to boot and I only have dual channel and not quad channel.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491752
I would just have one SSD for OS and main applications and any other SSDs for whatever you want on them. Probably games or some extra applications. I know all about buying multiple small SSDs for aesthetics. I currently have 3x Samsung 840 EVO 250GB drives while I could have gotten a 1TB drive for around the same price, I just wanted three of them to mount in my case to look good.
Laptops tend to boot fast from what I've seen, sometimes because the board/BIOS is designed to minimise pre-boot displays and options and sometimes because the laptop isn't actually off, it's just in a low power state. My laptop, which has a single 250GB SSD that's slower than my 840 EVOs in pretty much every way, boots a good 5 seconds quicker than my desktop.
If you have dual channel, that means you have 2x 16GB DIMMs, right? (going off your signature). Out of interest, why go for 16GB DIMMs? Personally, I like having as many of the RAM slots filled as possible.
My reason for buying multiple small SSDs:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491868
1 minute ago, Oshino Shinobu said:
I would just have one SSD for OS and main applications and any other SSDs for whatever you want on them. Probably games or some extra applications. I know all about buying multiple small SSDs for aesthetics. I currently have 3x Samsung 850 EVO 250GB drives while I could have gotten a 1TB drive for around the same price, I just wanted three of them to mount in my case to look good.
Laptops tend to boot fast from what I've seen, sometimes because the board/BIOS is designed to minimise pre-boot displays and options and sometimes because the laptop isn't actually off, it's just in a low power state. My laptop, which has a single 250GB SSD that's slower than my 850 EVOs in pretty much every way, boots a good 5 seconds quicker than my desktop.
Good idea, I will probably do just that OS on one, and main programs on the other one and 500GB SSD for games. Regarding the DIMMS, I was thinking to upgrade in the future, so this way each slot has the maximum amount of RAM possible. We have similar amount of SSD space, I have 120+120+500GB SSD EVO.
You're still on Z77? Woah dude, time to upgrade.
Thank you for explaining why laptops boot faster, I actually didn't know that.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491903
System was built about 3 years ago and haven't really changed or felt the need to change anything yet. Only thing I've really added to the system (and technically not even to the system) is about 10TB more storage in a NAS. 3770K is still plenty powerful for most things. Maybe next CPU generation I'll look into upgrading to a new platform, but that will probably be a complete system rebuild as I'll have to change the heart of the system anyway.
I do have plans for the complete rebuild, inspired by LTT's desk design but modified slightly and held together in a more practical way (crossdowels rather than glue). Stuff is expensive though, so I'd rather spend it on a new car or motorcycle than a £7000 computer that I don't really need (:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491958
I do have plans for the complete rebuild, inspired by LTT's desk design but modified slightly and held together in a more practical way (crossdowels rather than glue). Stuff is expensive though, so I'd rather spend it on a new car and motorcycle than a £7000 computer that I don't really need (:
That's fair. I have two systems, and I bought one with 4670K for 1080p gaming (it's a mini system, which looks good and has nice specs) and the second system is basically an overkill with 1080 TI and 6800K OC to hopefully 4.5Ghz. I know what you mean by spending way too much money on a system like that.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/749784-raid-0-fail-help/#findComment-9491976
