Hey Guys!
So I was going to build my very own PC for the first time, but I have no idea if this is anything near decent
I would appreciate tips and such, just change my PcPartPicker List as you please and tell me why u changed it.
Uses:
I will be using my PC mostly for 2560x1440 100Hz gaming, later on I will probably buy one of those Fancy 3440x1440 100Hz Screen, when its in my Budget
I will also be using my PC for Video and Photo editing (4K+) and 3D Rendering, all these things as a Hobby
Budget:
1800 Euro
Europe, use the German PcPartPicker
(Dont mind going a bit over it as I did)
Build:
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  (€361.44 @ Mindfactory)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  (€120.00)
Motherboard: Asus MAXIMUS IX CODE ATX LGA1151 Motherboard  (€341.74 @ Mindfactory)
Memory: G.Skill Trident Z RGB 16GB (2 x 8GB) DDR4-4266 Memory  (€200.00)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  (€251.84 @ Mindfactory)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  (€84.09 @ Mindfactory)
Video Card: NVIDIA GeForce GTX 1080 8GB Founders Edition Video Card  (Purchased For €600.00)
Case: Phanteks Enthoo Evolv ATX Glass ATX Mid Tower Case  (€193.84 @ Mindfactory)
Power Supply: Corsair 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  (€163.84 @ Mindfactory)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (€100.00)
Total: €2416.79
The Ram will be the 3200 kit
I already own the 1080
And yes some things are a bit overpriced, but Im also paying for looks
https://linustechtips.com/topic/748941-first-build/
If you want to do 4k video editing and modeling, then go with the ryzen 7 1700. you'll like having those 8 cores and 16 threads. i edited the part list for you. chose the crosshair because it was most like the maximus IX code you had, and i helped you save some money by putting in a lower wattage psu. also, nzxt will give you an am4 bracket if one isnt included.
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/748941-first-build/#findComment-9482662
IMO you are overspending on motherboard, RAM, PSU and storage.
Games rarely benefit from faster than standard SSDs.
PSU wise a Corsair RM650x will be plenty.
Motherboard wise you'll be fine with a more basic Z270 board like the Asus Prime Z270-A.
Im not sure how much RAM speeds will benefit editing but this is cheaper and still fast: https://de.pcpartpicker.com/product/qGqbt6/gskill-memory-f43200c16d16gvgb
And unless you are overclocking you should consider getting a cheaper air cooler.
https://linustechtips.com/topic/748941-first-build/#findComment-9482686
I two agree with Ryzen being the best option if you're not just gaming. The best ryzen from a price to performance perspective is the 1700:
http://www.gamersnexus.net/hwreviews/2827-amd-r7-1700-review-amd-competes-with-its-1800x
http://www.legitreviews.com/amd-ryzen-7-1700-overclocking-best-ryzen-processor_192191
Personal Rig:
[UPGRADE]
CPU: AMD Ryzen 5900X    Mb: Gigabyte X570 Gaming X    RAM: 2x16GB DDR4 Corsair Vengeance Pro    GPU: Gigabyte NVIDIA RTX 3070    Case: Corsair 400D    Storage: INTEL SSDSCKJW120H6 M.2 120GB    PSU: Antec 850W 80+ Gold    Display(s): GAOO, 现代e窗, Samsung 4K TV
Cooling: Noctua NH-D15    Operating System(s): Windows 10 / Arch Linux / Garuda
[OLD]
CPU: Intel(R) Core(TM) i5-6500 @ 3.2 GHz    Mb: Gigabyte Z170X-Gaming 3    RAM: 2x4GB DDR4 GSKILL RIPJAWS 4    GPU: NVIDIA GeForce GTX 960    Case: Aerocool PSG V2X Advance    Storage: INTEL SSDSCKJW120H6 M.2 120GB    PSU: EVGA 500W 80+ Bronce    Display(s): Samsung LS19B150
Cooling: Aerocool Shark White    Operating System(s): Windows 10 / Arch Linux / OpenSUSE
https://linustechtips.com/topic/748941-first-build/#findComment-9482767
I do agree with the SSD Speeds, I could go for a 850 Evo
750W is mostly for future SLI and OCing and its just 50$ more
Overpaying for looks, you wouldve know if you read
And the Ram I chose is also a 3200 kit, and Im also paying extra for the looks on these
Cooling = Looks
https://linustechtips.com/topic/748941-first-build/#findComment-9486383
Cooling = Looks
I stopped reading when i reached the parts list ¯\_(ツ)_/¯
https://linustechtips.com/topic/748941-first-build/#findComment-9486923
